Beko WM74155LW Washing Machine Not turning.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WM74155LW Washing Machine Not turning.
  • #101808
    Twoten
    Whenspin is selected, the pump runs for a few seconds then stops. No motor action.
    No motor action on wash.
    Motor tests OK and plenty of carbon brush remaining.
    Are there any common causes for this if not the motor?
    #486244
    a lot of them have a small board. top of the machine hanging on a plastic frame. only about 4 inches square with one plug on it
    check that baord for damage / bad solder joints etc
    Twoten
    electrofix wrote: a lot of them have a small board. top of the machine hanging on a plastic frame. only about 4 inches square with one plug on it
    I think it’s the DC board. I couldn’t see any damage or dry joints.
    #486246
    ok if dc board looks ok check wiring to motor
    just like you were able to see field coil, tacho and armature reading with a meter at the motor terminals you should be able to get the same readings from the other end of the cable. have had the odd wire break at the motor plug over the years
    can get a diagram if you need one
    Twoten
    electrofix wrote: ok if dc board looks ok check wiring to motor
    A diagram would be handy, thanks.
    #486248
    sorted
    Twoten
    electrofix wrote:sorted
    Thanks Dave,
    I did try and bell out the wiring loom but as the wires don’t go to a specific motor plug it was difficult to know what was connected to where. This will make it a lot easier to check.
    #486250
    Twoten wrote:
    Thanks Dave,
    they also go through the bridge rectifier on the DC board so you cant bell direct to the board
    Twoten
    Motor and wiring checked out OK.
    Replaced DC Board which resolved the problem.
    Thanks for the help.
