Beko WM74165W vibration noise
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WM74165W vibration noise
  • #101231
    Shroppyfly
    Hello Experts , i came across this washer and it fills,heats,spins,drains so ermm works , except on spin, it has a permanent noise, now if while spinning i lift up either side , or lift up front or back the noise goes, so before i get spanner rash, has anyone clue what i should first look for, its obviously a vibration noise( he says with hope lol), so drum, suspension, motor mounts?i dunno, but as its a beko , hoping its a known noise, So even at 7-30pm sat evening, yes I need a life, BUT after removing the back panel and top , i ran it on 28 minute wash to try and narrow down the location of noise, when it was on spin, if i pushed the concrete block forward , the Noise went, tried it a few times and yes Noise goes with an ear to it , the noise does seem to be coming from the door area
    Cheers in advance
    #483934
    just check the weights have not come loose
    Shroppyfly
    Dave , cheers for that, up early watching the f1, bound to be another red flag, ill get the sockets out in between lol
    #483936
    Shroppyfly
    electrofix wrote: just check the weights have not come loose
    Dave,So checked weights at front and underneath, , all needed no more than a quarter nip up at most, mind you the filter had more coppers in it than you will ever see on the streets so ill reassemble tomorrow and re try it , unless while its apart(again making good use of the kitchen table), the mrs is overjoyed, shes speechless.:eek: theres anything else i could easily check look at?
    #483937
    no put it together and see how it goes
    if the coins were blocking the drain water banging on the drum makes quite a noise
    Shroppyfly
    electrofix wrote: no put it together and see how it goes
    Dave excellent advice, popped it back together(Mrs) happy again lol ,and on a 28 min wash all is quiet
