Beko WM8127S
  • #64065
    loopey
    Stuck on 2 mins , switch on door locks shows 00.02 in the display
    checked all the usualls , no low insulation every thing megged fine . fitted new pcb and and its the same , i am stumped on this one . :bang: .
    #355938
    Criscold
    Re: Beko WM8127S
    I don’t know this machine,This may be a silly question & I know you say you tested everything but could the 2 be an error code
    error 2 = heater o/c. If you need test info let me know
    Colin
    #355939
    loopey
    Re: Beko WM8127S
    I shal check that out , yes please iff you could send the test info thanks colin
    phil
    #355940
    Criscold
    Re: Beko WM8127S
    You should have mail
    #355941
    loopey
    Re: Beko WM8127S
    well i found what it was , the selector switch little brass
    brush had gone missing
