Can anyone help I was called out to two Beko washing machines today and found they both had the same fault. you set any programme it comes up with time duration the it starts to drain and comes up END and the arrow and end start flashing then the pump stops and it goes back to the time then this goes on and on until you switch the machine off does any know how to stop this .
pleases can you help
Les
