Beko WM95145LW stuck on 20 mins.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WM95145LW stuck on 20 mins.
  • #83835
    aqualectric
    Beko WM95145LW 8kg washer. XL 2879500800. 28/09 2012.
    Switch on, display lights up, door locks and pump starts and stops in short bursts; 20 mins shown on the display. Nothing else will work. Tested all parts with megger – all OK. Can’t cancel or change the cycle by any method.
    Methinks it’s the module….. but there is a little black transformer fitted at the back of the machine….. what does this control?
    Any help on this?
    Cheers,
    Steve.
    #423912
    geoff1
    Re: Beko WM95145LW stuck on 20 mins.
    Have send you some information on unit.
    Had 2 similar which gave fault code of F13 in service mode.
    these turned out to be motors.
    Have had issues with modules but mainly tend to go dead.
    Check voltages out to motor from module if you can.
    Geoff
