BEKO WMA 10W TIMER FAULT
  • #33015
    MC
    got a problem with a beko wma 10w washing machine, the program dial keeps on clicking round, any ideas?
    #237125
    Dales-Electronic
    Re: BEKO WMA 10W TIMER FAULT
    Before you do anything – check this, once you have set the timer to the required program and switched on, the timer then locks the selected program in memory. The knob then rotates around to the end of that part of the cycle ie wash. This is quite normal. If however you have got it continuously circulating then you have got a problem. :rolls:
