Re: Beko WMA 1512W washing machine
Does the timer make step in 75seconds or 2,5 minutes with 2,5seconds long left and right turns and finish the program rapidly? (YES:- ) The triac that drives the timer motor is short circuited. Change the timer. (NO:- ) Disconnect one of the cables of NTC and control its resistance. R>75kohm? (YES:- )If the NTC is faulty, the timer advances to the stop position without agitation.Change NTC. (NO:- ) Check if the socket of the temperature adjustment potentiometer and its correspondence on the timer placed properly. Check if the push button of quick function is a normally open button. If these are OK, change the temperature adjustment potentiometer.
Hope it helps
