beko wma 1614w
  • #34098
    funkyboogy
    timer just clicks round to the off pos,
    when you select any prog..
    any ideas where to start
    cheers ally
    #241240
    helo_75
    is that the one with the ‘speed control’ pcb?
    because that often causes it
    as does duff brushes
    #241241
    Dales-Electronic
    Re: beko wma 1614w
    Yep both timer and module listed seperately
    #241242
    funkyboogy
    Re: beko wma 1614w
    would it be best to try brush,s and speed control module..
    ive not done a lot of work on these apps..
    should of said earlier ive not been yet just going on what customer has stated..
    cheers a;lly
    #241243
    Martin114
    Re: beko wma 1614w
    Did one the other day doing same fault and it was the timer. Have had a few in the past as well – all the same problem.
    funkyboogy
    Re: beko wma 1614w
    cheers..
    will try timer,
    ally
