Beko WMA 510S – pulsing cold water supply on spin cycle??
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WMA 510S – pulsing cold water supply on spin cycle??
  • #39278
    WotThe
    Hi, my first post on here….
    Our Beko WMA 510S has developed a strange fault. On a spin cycle, the cold supply to the machine ‘pulses’ for a split second about every twenty seconds or so, it’s enough to create a ‘hammering’ noise in the cold water pipes.
    I’ve removed the hose to the water pump and I won 25p on the washing machine lottery, along with a few bits of fluff. The noise, however, persists even though I know the pump is clear now.
    I’ve verified it was the cold feed as I can feel the ‘pulse’ through the cold tap and can see water drip for a split second in the soap tray when the ‘pulse’ goes off.
    Can anyone tell me how to cure this please?
    WotThe
    #261880
    Re: Beko WMA 510S – pulsing cold water supply on spin cycle?
    Electrical noise from the drive motor will be causing a corruption issue in the computer board.
    This may be being caused by the carbon brushes becoming low or sticking in their holders, an excess of carbon dust allowing slight earth leakage or the motor itself may be breaking down.
    Power off if you intend to investigate this yourself.
    WotThe
    Thanks, I’ll start by changing the brushes.
    #261882
    WotThe
    OK, new brushes have been fitted and there’s no difference, in fact over the last week or so it’s been getting worse.
    I think it’s a motor out job now, to make sure that everything is clean and free from carbon dust.
    #261883
    bazza500
    The next thing I would change is your user name.
    #261884
    Users can’t.
    I did.
    helo_75
    does that mean he wont be able to log in now? if his user name is different and he’s not changed it.. what happens now?
    #261886
    Nothing changed on the account bar the name and the login should be the same. The OP can see the change when he looks at the replies.
    WotThe
    Sorry about the name, I didn’t mean to cause offence. 😳
    I cleaned the motor up and everything is working fine now; thanks very much for all of your help, I am very grateful.
