Beko WMA1512 No start.
  • #31876
    cornwell40
    When you set a programme the door locks then you get the grinding sound of a timer advancing (but it doesn’t). The noise continues on a regular basis but the machine doesn’t fill or anything else. When i selected spin, I got drain for a few seconds then it continued the same as before. Suspect its the board rather than the selector/ timer but anyone else come across this fault.
    TC
    #232778
    robbra
    Re: Beko WMA1512 No start.
    Had many timers fail under guarantee, either nothing happens or a wash takes 5hrs+ or just never finishes. Having said that the boards go too but I would try the timer if the grinding sound is coming fom it.
    Rob
    Sometimes these are a bit of a lottery
    #232779
    trotter
    An open circuit (Or sticking) drain pump causes VERY similar fault, just a thought and worth a try just to plug another pump in?
    I had one of these that kept getting blocked I went back to it three or four times and on the last visit the pump was intermittent and it just wouldn’t stay on the selected programme.
    The pump was faulty.
