Beko WMA1512W a/w
  • #36045
    Complaint of dial clunking round – does the usual preselector thing, clunks forward to fill, then again to heat – but – no heat. I assume it’s timing out and aborting to the end.
    Heater and NTC are functional, so the question is board or timer? Heater feed is off the p/sw and front row of the timer unit, but I assume that it’s controlled by the board. Unless it stops heating by advancing the timer?
    :conf: :conf:
    aqualectric
    Re: Beko 1512W a/w
    I had a very similar problem to this – the timer kept aborting when washing. It ended up being the PCB causing the fault. Took a while to sus it out though…..
    Have a look here:- http://www.emwelec.co.uk – stock item.
    HTH,
    Steve.
