Beko WMA1512W sticking mid cycle
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WMA1512W sticking mid cycle
  • #19396
    geoffmackay
    Beko WMA1512W which will not anvance during cycle. It fills ok to correct level then washes and heats. it then sticks prior to draining and rinsing. One click on the timer and it runs through the rest of the cycle ok. We have changed the timer, module, heater, thermistor, pressure switch, solenoids…..everything bar the pump and motor.
    Surely its some kind of heater fault?
    Then by chance this morning i pressed the quick wash button and it advanced.
    Question is just what does that button do on this machine?
    Had 3 different answers already.
    #182948
    Re: Beko WMA1512W sticking mid cycle
    Are you sure the replacement module was the same as the original? Beko seem to do identical looking modules with subtle differences….
    #182949
    geoffmackay
    Didnt check number on board but everything looked the same.
    #182950
    aqualectric
    Geoff, check this with Tony (EMW). They do Beko PCB’s now and you can be sure to get the right one and it’s tested. They’ll also have a list of common faults to look for on those boards. EMW (01159) 652118.
    Maybe that will help!!
    Steve.
