beko wma1715
  • #37662
    wilf
    machine dead apart from light on door release button. I suspect main module rather than the display board as everything tests out motor heater etc door interlock is a 4 wire unit but I assume that a display should show even with the door open. anyone any ideas or tips as the board is expensive to just take a flyer on and Ive not had this before.
    thanks wilf
    #255978
    Re: beko wma1715
    I have changed the odd board one these, damage is usually visible, however EMW will test/repair these boards Wilf.
    Seamy
    Re: beko wma1715
    Luckilly parts are quite cheap, boards do go, i’ve had to replace a PCB & motor on one of these recently. Check for breaks in cable loom, they have a tendacy to break the fine cables, especially ones going to solenoid valves, the top weight sometimes hits off loom & shorts out to frame & takes board with it.
