beko WMA1715
  • #45891
    wilf
    only had a quick look at this so far as customer was just on her way out. select program door locks but no action. of the five lights on the right the top one ( prewash) is lit
    before I go back does anyone know what this error code is?
    wilf
    #287526
    bzz67
    Re: beko WMA1715
    not sure of codes but nogo is often carbon brushes or broken wire to motor like on the whirlpool machines.
    #287527
    Re: beko WMA1715
    Use search facility “beko + prewash + 1715”, narrow down to trade tech enq only. To get more results use fewer terms or switch them about. Here’s one interesting result another Beko saved from the scrap heap
    Mike.
    #287528
    Re: beko WMA1715
    ‘+ ‘won’t work, Mike, you have to use ‘AND’ between words.
    Re: beko WMA1715
    😕 Funny, I got relevant results 😕
    Mike.
    #287530
    wilf
    Re: beko WMA1715
    just been back tried the child lock routine, no difference! everything checks out looks like the board…. but which one?????????????
    wilf
    #287531
    chris211
    Re: beko WMA1715
    Hi mark did i not do you the disc with the diagnostics for the beko machies that should tell you how to diagnose the faults
    #287532
    wilf
    Re: beko WMA1715
    yes chris you did forgot about that thanks
    wilf
    #287533
    wilf
    Re: beko WMA1715
    chris Ive looked at the disc and found some codes 🙂 (I hate acrobat reader 😡 ) which Ive put on known errors still think its board as machine wont do anything but flash prewash. EMW list this as common fault
    wilf
