Beko WMA1715S dead
  • #18536
    aqualectric
    Beko WMA1715S Ser.no. 0311420012
    Machine switched on; programme selected; few seconds later the prewash lamp flashes continuously – start button has no function. ‘Door open’ lamp still lit. Door interlock does not activate.
    Changed the door interlock – no difference. But when the machine is switched off and then switched on again with the start button held, door lock activates. 😕 Every now and again the water valves will ‘blip’ momentarily.
    I am pretty sure it’s the PCB at fault but with the customer only wishing to spend £100 at most on a repair, I need to be sure when I call him tomorrow.
    Thanks in advance for any info,
    Steve.
    #179360
    Re: Beko WMA1715S dead
    Pre wash light flashing is either…
    1) Child lock activated
    2) A failure that has to be investigated by an engineer.
    By that I mean powering down will not clear the fault.
    To enter fault diagnostic
    1) power off
    2) timer at 12 oclock position
    3)press and hold start button whilst turning power ON, STAR icon will start to flash within 3 seconds
    4) turn timer knob to any SPIN programme
    5) press start button once more
    6) Read the binary code of lights on the right hand side of the control panel.
    Read top to bottom: on =1, off =0
    7) after noting the failure, erase the error code by once again pressing the start button** for three seconds this time***
    The fault LED’s will extinguish.
    the following are the indicated binary code, reading top to bottom
    10000 NTC
    01000 Heater
    00100 Triac on the board
    10100 Pump open circuit
    11100 Water level sensor
    01100 Motor or tacho open circuit
    There are more fault codes but these are the ones responsible for the pre wash light flashing.
    Watch out on the pump, some have a fuse link in the wiring, pump test ok, but the wiring won’t.
    Over foaming can also bring on this fault as the electronics is measuring “current” drawn by the components.
    To exit the above fault diagnostic……power off once fault cleared.
    Hope that helps
    Kevin
    #179361
    funkyboogy
    had this recently, and ….
    it was the pcb
    cheers ally
    #179362
    aqualectric
    Thanks very much for the replies. I’ll try the diagnostic route today – great to have that ‘inside’ information. Cheers!!! 😀
    #179363
    Tony_EMW
    We now test/repair these boards !
    Tony
    EMW
    #179364
    agro
    On this model i have had several of these faults and normaly find the pump struggling Due to the board you have to replace both pump and board or it nocks the pump out again
    #179365
    keithwilliams
    had a couple of these boards with dry solder joints.
    #179366
    aqualectric
    Thanks all! But as usual, with the utterance of the words ‘PCB or computer failure, madam’, the reply comes, ‘Nah, don’t worry, I’ll go and get a new machine’. 🙄 .
    At this rate, the highest peak on the planet will be the white goods mountain; never mind Everest. 👿
    #179367
    Last board I bought for one of these was about £45 – very affordable.
    Pre-wash option lamp flashing indicates “child lock” function; pre-wash programme lamp flashing is a technical fault – every one I’ve seen to date has been a board fault.
