Beko WMA510 – Lights Flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WMA510 – Lights Flashing
  • #54761
    Allsorts
    Anyone know the codes for this machine ‘Beko WMA510W’?
    I have the rinse hold light flashing for about 2 secs and then the ready light flashing constantly.
    George
    #320899
    Allsorts
    Re: Beko WMA510 – Lights Flashing
    Does anyone have a service manual for this one?
    George
    #320900
    cab
    have you checked the motor brushes? when worn these throw up silly faults, dont know of any fault codes, also check it is not in child lock or stuck in a program, i.e. cancel and reset.
    #320901
    Allsorts
    Yes, Motor brushes are like brand new
    George
    #320902
    Galway
    try resetting if no good then check element and ntc connections door lock if no good probably the pcb.have had aq few of these but usually resetting sorts it.
    #320903
    Child lock?… 😯 😕 😆
    #320904
    Allsorts
    Result : One of the wires to the motor block had an internal break.
    George
