Beko WMA510 No spin amongst other things
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WMA510 No spin amongst other things
  • #57256
    nelson
    Called out to this one last night, the customer had complained that the machine doesn’t drain and spin sometimes, and that earlier in the week it took seven and a half hours to complete a wash cycle 😕
    I ran a spin program which started and picked up into a spin no problem.
    I checked water pump for blockages etc nothing there, checked carbons on the motor they were approx 2/3 worn but still plenty of length on them.
    I ran the machine on a rinse and spin, the machine filled turned once then didn’t do anything else, I gave it a couple of minutes but then cancelled the program and selected spin. This time the machine began pumping but stopped after about 30 seconds, with no drum action at all.
    I had assumed that the board must be faulty because of the random nature of faults, but on reflection I am wondering about the brushes.
    I have in the past had a fault on a Beko where the machine starts and cuts out after about 20 seconds due to the carbons being worn out.
    Any thoughts?
    #330413
    nigegt
    Re: Beko WMA510 No spin amongst other things
    Have had broken wires on motor plug before and it’s really not obvious. I changed the motor before i noticed it 😳 , gave each wire a good tug in desperation and bingo. If not i’d go for the board.
    Nige
    #330414
    nelson
    Fitted a new module and everything is ok now 😀
    Cheers Nige, I tried the motor wires before ordering the board.
