Seems to be difficult to get info for this model. 6205/6206 seem to fit a lot of models though. Maybe you’ll be able to get the info off the old seal, even though it may mean an extra trip. Alternatively,if the job is really distant, type Beko bearing seal into Connect’s search box and buy one of everything that comes up in stock. About £20 and you’re pretty well covered. Or £7 for just three different seals.
Mike.
Yes, strange 😕 You can get a blow up diagram on Connect Mediator but the only bits that look like they might be bearings are not in the parts list. For the small shaft Bekos you can use Electrue kit BRG9107, a lot of the larger shaft ones use seal 270108000.
Mr Conway is a quiet, unassuming and unheralded genius. Until the fourth pint. Piccie.
Spares@ is quietly taking over the world, so Dave isn’t on much these days. If you open an account with spares@, you will get a concessionary rate against the retail prices.
