beko wma510s not moving through wash sequence
Home Forums Public Support Forums Help And Support Washing Machine Help Forum beko wma510s not moving through wash sequence
  • #55710
    lee39
    i have a beko wma510s machine,it fills,washes fine but needs to be manually moved on to rinse and spin.i have checked bushes and seem to be ok,any ideas will be much appreciated.
    #324853
    Re: beko wma510s not moving through wash sequence
    May be a heater fault.
    Remove mains plug, take off the back panel and test the heater with a megger or multimeter.
    BTW, I think you may have actually checked the brushes, bushes are those green things in the garden. 😉
    #324854
    lee39
    yes i meant brushes(typing error).i have checked heater with multimeter,checks ok.machine heats up during cycle.
    #324855
    Does it stop completely, just keep on tumbling from side to side or does it start to drain then stick?
    #324856
    lee39
    it washes then it pumps water out then drum turns but doesnt add water for rinse unless you stop machine and manually turn it to rinse.after rinse it then needs to be stopped and manually turned to spin.
    #324857
    Not sure if that particular machine has a mechanical timer or a fully electronic PCB.
    When you say it doesn’t add water, can you hear any water running but not actually filling into the drum?
    It does sound like a timer fault TBH though.. 😥
    #324858
    Seamy
    Maybe filter blocked & machine not emptying all water or appliance drain hose too far down waste pipe & is syphoning on next fill.
    #324859
    lee39
    machine has electronic pcb.ran it through the mini 30 minute cycle,it filled,washed,drained,rinsed,drained then when it was suppose to go to spin but the drum just turned both ways at low speed until i manully ended the program.
