Beko WMA510W
  • #58686
    Lawrence
    machine does most of the cycle then drains and wont advance ,if you put it on rinse and spin its fine ,element okay ,changed PCB fault still present ,pressure system clear etc .
    any pointers
    Lawrence
    #335295
    Galway
    Re: Beko WMA510W
    ntc on element?
    #335296
    dave-m
    Re: Beko WMA510W
    Lawrence,
    Sounds like its not spinning all the time?
    I’d check the wiring to the motor and the magnet in the tacho. Those magnets are troublesome and any damage to them can make it spin intermittently.
    dave
    #335297
    Re: Beko WMA510W
    “rinse and spin” = last rinse? = fill via cond. valve?
    You see what I’m getting at.
    Mike.
