BEKO WMA510W
  • #62591
    johnnyj
    I was at a Beko WMA510W today when switched on it comes on with the Ready and wash lights falshing with spin light on constant with the pump running no matter what you do it will not cancel i was thing it mustbe a duff module, i checked the known error codes but am a bit stumped with this one any help would be most welcome cheers JJ
    #350579
    colly
    Re: BEKO WMA510W
    Common fault on beko is motor brushes .
    I have had a one that would not cancel at all .
    I tapped the back of the motor a few times so as to make brushes make contact.
    I then found drum would rotate and i could now cancel the programme.
    New brushes fitted cured the problem.
    Worth a check
    Colly
