Went to this machine today the owner said it was taking forever to finish a cycle and when it did the clothes were still wet…Machine seems fine in all areas, heater, solenoids, pump etc. I had to be elswhere and told her to put on a cold wash to see if that would get thro…..3 hours later it was still going. I think were in pcb country and I hate that country. Anyone any other suggestions. Anyone have a part number for pcb?
2822640073 @ Connect £28.79 I’d explain to customer that there’s no way to be sure without trying it and get them to take the financial risk or at least a portion of it.
Mike.
Hi there, you have to change the PCB as it is logging a foam detection which will activate extended rinses up to an additional 27 rinses can be added. If you change the pcb to the new type, it will eliminate this problem the part number is 2822640073.
