Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko wma5120w not working at all
- This topic has 4 replies, 3 voices, and was last updated 12 years ago by
Steffy.
March 12, 2014 at 6:57 pm #79923
Steffy
ParticipantHi, I have just aquired a beko washing machine but after having it plumbed in it doesn’t appear to want to do anything. I have cleaned out the filter and tried switching on and off in the attempt to reset the programme to no avail. I have also tried holding down startcancel buttons. All I get when turned on is a flashing ready light.
Any help or advice would be much appreciated.March 12, 2014 at 10:25 pm #411061roly16
ParticipantRe: Beko wma5120w not working at all
Have you checked the obvious things such as water tap turned on, and made sure the door is shut firmly? If so, I think it’ll be a job for a service engineer.
March 13, 2014 at 12:53 pm #411062THE GRAND WIZARD
This sounds all too familiar. I have a brand new Beko WM7043CW washing machine. I removed the existing (fully functioning 20 year old Ariston!) and connected the new Beko. Just like your model my Beko simply refuses to start; there is water, there is electricity, there is a drain outlet (all tested and retested and retested….) but still no lift off!!!! I rang Beko and a menu driven “customer service rep” went through the usual checklist (which I had already done anyway). I am now awaiting an engineer who is scheduled to visit on 17/03/14. Ariston is back on active duty!!!!
March 17, 2014 at 11:17 am #411063THE GRAND WIZARD
Just an update on my previous post. The engineer visited today and discovered that the PCB control board was not seated correctly. Therefore, the Start/Pause/Cancel button simply wasn’t making physical contact with the board. A quick push and the lugs clicked into place; a fully working machine! Beko final QC should be better.
Hope this helps.
March 18, 2014 at 1:29 pm #411064Steffy
Many thanks for all your help and suggestions so far. Will have a look at PCB board to see if mine is the same otherwise looks as though it may be a call to the engineer.
Will keep you posted. -
