beko wma520
  • #73479
    clockworkone
    Went to this one this morm. Will fill for a matter of seconds only and then wont reset.Turn off at plug and press start and it does same.Checked valves, heater,pump.Brushes worn out so replaced. Tried again and still the same.
    #387602
    Re: beko wma520
    sound a lot like a board power supply problem
    check main pcb if power supply uses capacitor change it and see what happens. if its switch mode then its not that
    see
    trade-technical/simple-pcb-repair-tips-t51155.html
    for more info
    clockworkone
    Re: beko wma520
    Many thanks Dave.
