Beko WMA520W and ISE5.
  • #32326
    megawatt
    Had the same fault on both of these machines this week but in both cases I could not find a fault and left them on test.
    Customers complained of burning rubber smell at end of spin. Both machines about 1yr old, spiders feels ok and drum not rubbing on boot. On closer inspection I find small bits of melted boot rubber on the lip of the drums. This is just the same as you would see on a bearing failure when the drum comes into contact with the boot. Tested both machines on spin with wet washing and found ok????? Does any one have any ideas or come across this before ?
    Mike.
    #234697
    Re: Beko WMA520W and ISE5.
    We’ve only ever seen it as a result of clamp damage, where the front is slightly pushed in. Aside from that it’s not a known issue.
    helo_75
    erm, actually, it is
    theres a new modified door seal to fit it….
    not got the part number to hand, typically, but ill get it
