Beko WMA620W Door assembly does not fit
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WMA620W Door assembly does not fit
  • #60767
    Twoten
    I have been asked to supply a door assembly.
    The part supplied by Connect is pt No. 2878300200.
    According to the technical sheet it says:
    “here is technical info reference fitting this part. You must read this bulletin please note old and new ar e compailtable but you must fit the whole unit. The hinge may be different to the original but will fit.”
    When the engineer who purchased it tried to fit it he said the locating lugs are in a different position so it is not possible to fit the hinge as the lugs prevent the moulding from fitting flush with the cabinet.
    Has anyone have the answer to this?
    #343544
    Seamy
    Re: Beko WMA620W Door assembly does not fit
    Hinge & support need to be changed together. If they don’t locate properly them its an old type front on the machine & this also needs to be changed.
    #343545
    Twoten
    According to the tech sheet the part number for the front panel is 28124100 and the same for old and new door.
    It says front door assembly change does not have any effect in front panel!
    I see there are different versions of the hinge support, but this isn’t mentioned in the tech info from connect.
    #343546
    Seamy
    Its mentioned on the Beko technical website & shows graphic of different cut-out in the metal of front to accomodate changed support, can e-mail you info if you need it.
    #343547
    Twoten
    Thanks Seamy,
    That would be useful.
    #343548
    RickT
    Hi, Any chance of sending me a copy 🙂
    #343549
    Twoten
    Check your PM
    #343550
    RickT
    Many thanks. 😀
