BEKO wma665w – error code IL
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BEKO wma665w – error code IL
  • #25125
    KWRIGHT
    I hope you can help me, we have a BEKO washing machine model no wma665w serial no 051024870
    The error code indication is the led flashing on speed 1200 and the display indicates IL, the leds flash in unison. Controls are locked, the main motor is ok all so the pump and fill valve, have tried reseting but reverts back error code.
    I do hope you can help me solve the problem thanks very much!
    #204596
    stefan
    Re: BEKO wma665w – error code IL
    We have the same problem with our Beko washing machine.
    IL is mentioned in the display (I flashing), and the 1200 spin light is also flashing. Any suggestions about the problem and the way to fix it?
    #204597
    kele
    also have the same problem as above called an engineer out he came to today and said it was the main board ❓ said it would cost around £150 plus vat only paid £280 for the machine about 16 months ago do anyone know wether this is the right diagnosis and would i be able to get it done any cheaper or should i bite the bullet and buy a new one thanks
