Re: Beko WMA667W no motor action and displays ’00’
Stop Press.
Went out to this today.
’00’ was in fact’0000′, and was indicating end of cycle – albeit only 20 mins after start of cycle.
Soldered across burned out track on module.
Tested on spin and was ok at first, then as it reached 1400rpm, machine started belching out smoke – motor was burning.
Apparently, this is how the motor failed the first time, except then it didn’t take out the module.
Looks like a common fault on this machine – be warned!
