beko wma745
  • #65420
    wilf
    customer reports machine cuts out after 6 mins. heater open circuit replaced and all seems well. but the same fault shows again, any ideas?
    wilf
    #360425
    Criscold
    Re: beko wma745
    Have you tried test mode on this to check error codes ?
    Colin
    #360426
    Re: beko wma745
    let me have your email address wilf
    wilf
    Re: beko wma745
    thanks Dave
    nothing does as said in the list (different order and other things) no error codes came up and on position 2 it comes up 429.
    board?
    wilf
    #360428
    Re: beko wma745
    if you let me have an email will send you the fault find chart and test prog info
    in fault find it gives a list of resistances for the prog selector
    1. Position ~1 Kohm
    2. Position ~2 Kohm
    3. Position ~3 Kohm
    4. Position ~ 4Kohm
    5. Position ~ 5Kohm
    6. Position ~6 Kohm
    7. Position ~7 Kohm
    8. Position ~8 Kohm
    up to
    16. Position 16 Kohm
    so approx 1K per click check that
