Beko WMA765S
  • #53730
    subs
    This machine will try to start but then stops and does nothing. For example, put it on drain or spin and it will lock door activate pump for few seconds and thats it. Now, yes ive checked brushes they are ok and ive checked absalutly everything. Ive done test sequence and it does everything except motor action. No errors shown. Now is this duff motor (motor checks out ok although field coil had low insulation reading) or control board?
    Any Help Please?
    Subs
    #316988
    johnnyj
    Re: Beko WMA765S
    Just fitted a Module i rescued from a scrap WMA510 for the same fault and it cured it, i guessed it would be the module as it filled and i could not hear any relay clicking to power the motor, but the again i just think i was lucky JJ
    #316989
    TheSpinDoctor
    Re: Beko WMA765S
    Hi Subs.
    Check your PM’s mate.
