Re: Beko WMA765S a/w
Penguin45 wrote:Door open light stays on.
I assume you mean the door doesn’t lock.
If so, 2 x 240 sounds like one too many. I’d open the old interlock and find out which wire was meant to be neutral, assuming switching is on live side. If one of your 240 should be 0 then follow that wire back to board.
But I suppose with a huge workload like yours it’s easier just to order up the board (£30+) and try it. 🙂 Terminal 4 is probably to do with door open light, like on Zanussi but in reverse.
Mike.
