Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › BEKO WMA765S No display.
- This topic has 31 replies, 8 voices, and was last updated 15 years, 11 months ago by
iadom.
May 16, 2010 at 10:27 am #320036
ModeratorRe: BEKO 765S No display.
Well according to Beko the module I need is a 2822380311. :con:
May 18, 2010 at 12:42 am #320037Penguin45
ParticipantRe: BEKO 765S No display.
Assuming it’s a WMA765S, that part number is correct.
C.May 18, 2010 at 8:32 am #320038admin
KeymasterRe: BEKO 765S No display.
iadom wrote:Well according to Beko the module I need is a 2822380311. :con:
I found this here : Module
:rolls:May 18, 2010 at 9:00 am #320039iadom
Yes, I spotted that one as well Adrian, both myself and Masterpart are still puzzled as why Beko UK insist that 2902260100 is not a genuine part number even though a Google search brings up pictures of the darned thing. 😕
May 19, 2010 at 11:18 am #320040admin
KeymasterRe: BEKO WMA765S No display.
I’ve looked again after some info… but what I have found was, the same thing: yours isn’t in database, but the other one is. 😈 👿
I cannot find a way to see on which products (models) are fitted…8)
May 19, 2010 at 6:09 pm #320041SparkyP
ParticipantRe: BEKO WMA765S No display.
Hi Iadom
The part number you need is 2817740310. If the display is either not on or a few lit leds the main card is at fault….HTH
Sparkyp
May 19, 2010 at 7:42 pm #320042iadom
ModeratorRe: BEKO WMA765S No display.
Well according to BEKO and the Shop@ here the part I need is 2822380311.
Its on order so I will update as soon as it arrives.
May 19, 2010 at 10:03 pm #320043leavemetogetonwithit
Work expands to fill the time available. 😆
Mike.May 19, 2010 at 10:05 pm #320044Allsorts
Does it? … Lucky bugger.
George
May 19, 2010 at 11:00 pm #320045leavemetogetonwithit
No, I mean it sounds like the WM series brush jobs are finally beginning to run out, even in Oldham. 😆
Mike.May 20, 2010 at 8:51 am #320046iadom
Did a set yesterday afternoon. 😛
May 20, 2010 at 2:13 pm #320047leavemetogetonwithit
Old(ham) Hotpoints never die! Hey, you could write that on the side of your van!
Mike.May 20, 2010 at 3:36 pm #320048iadom
leavemetogetonwithit wrote: Hey, you could write that on the side of your van!
Err, no I don’t think I should, do you. 😉
Jims ‘Van’
May 30, 2010 at 8:59 pm #320049iadom
Just to put this one to bed, a new 2822380311 PCB sorted the problem. 8)
Now if only I could get someone to rewrite the eeprom on the displaced PCB I would be even more pleased. 😉
June 1, 2010 at 11:57 am #320050admin
iadom wrote:Just to put this one to bed, a new 2822380311 PCB sorted the problem. 8)
Now, if you have no more in hands the new/good PCB on hand (in order to read and store eeprom content) is a missing job…In order to rewrite eprom you have to find an local “TV” repair “guru”/guy :rolls: and he will do the job… 😉
