beko wma765s stops at rinse
Home Forums Public Support Forums Help And Support Washing Machine Help Forum beko wma765s stops at rinse
  • #78279
    lmarch48
    Hello, can anyone give me an idea of what my machine problem is. Its a beko WMA765S and on all wash programs it runs ok until it gets to the rinse and stops and doesn’t do rinse. Mostly it just shows the time remaining and a steady rinse/conditioner light but doesn’t move longest i left it was just over an hour and nothing had changed. But maybe twice an error code H7 was shown with flashing prewash/main/rinse lights, thank you
    #405072
    lmarch48
    Re: beko wma765s stops at rinse
    follow up hubby has checked the pressure sensor connections and pipe as per H7 error code solution and they were ok, He doesn’t have a continuity tester but if machine fills for wash as usual are we correct in assuming it works both fill and rinse must use same sensor or are we way off. A friend suggested solenoid at the inlet so he switched the blue with the pink wires and both filled machine okay.
    #405073
    Andy jones
    Is it pumping out. If not check the pump/filter
    #405074
    lmarch48
    yes the machine pumps out the wash cycle water but wont fill back up for the rinse, just hangs at that point. We tried resetting with the 90 degree/start-pause/power button combination , the individual rinse program just refuses to start.
    #405075
    Take a closer look at the Pressure sensor system. Make sure the air chamber and hose aren’t clogged with gunge.
    #405076
    lmarch48
    Hello, thanks for suggestions, I had him take pipes for the sensor off there was a film of slime, for lack of a better description, on the lower section of pipe where it connects to the drum the thin pipe that leads to the sensor itself was clear but he flushed it to be sure. He blew into the sensor and could hear the switch activate inside when air pressure was applied. Stripped drawer apart and cleaned the jets/slots out while he was there, Put it back together and it rinsed this time then froze at conditioner, with no flashing lights or error codes just timer showing 15min.
    #405077
    lmarch48 wrote:Put it back together and it rinsed this time then froze at conditioner, with no flashing lights or error codes just timer showing 15min.
    Sounds like the water inlet valve is playing up then. Stick a new one in, very cheap easy fix. One available HERE 😀
