Beko WMA765s stuck at certain time readouts
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WMA765s stuck at certain time readouts
  • #44349
    Sparkcymru
    Got a Beko WMA765 that will start up fill and drum turns but it hangs at 1 hour 18 mins remaining and just keeps washing or if you select a spin only it starts at 19 mins drum turns but at 18 mins it just sits there pumping with no further progress. Is this module fault or is it the display board with the time readout on at fault?
    #280701
    robbra
    Re: Beko WMA765s stuck at certain time readouts
    Hi, Had one like this 18 months ago and it was the element but worn brushes can give spurious faults also.
    Rob
    #280702
    Sparkcymru
    Well replaced the brushes first and no change so sent module for repair came back all worked fine until end of program when the door interlock wouldn’t release the door and the module failed again. Put new interlock in and replaced the module and all working fine since. Hurrah!
