Beko WMA765S washer. Serial no:- 05 10264209
Switch on; the fascia lights up, door push button lights, press start, nothing. Yet it will run the test program in the UKW code book. 😕
So all the main components work, but the PCB won’t run the machine. I removed the boards and cleaned the connections and refitted them. Now the test program goes as far as the motor rotation function and will not work. Is it likely to be the main PCB or the fascia PCB? Or both? Also, what does the small PCB with the large heatsink at the back right of the machine do? Can’t see it listed on Connect.
Any pointers? Am I missing something?
Steve.
