This machine is trying to spin on the wash cycle: similar to the ‘jumping on wash’ fault common on old Hotpoint 95’s with burnt timer contacts. I have tested for earth leaks and the motor tacho – all seems OK.
I’m pretty sure it’s the main module behind the control panel; anyone had this fault before?
I assume you have checked the wiring harness for breaks, I have had a couple of BEKO machines with breaks at the motor plug that only revealed themselves after I pulled on the wires.
Thanks guys – I’ll get a PCB then. All the wires checked and continuity tested Jim…..all OK hence the question. Fortunately the PCB is very cheap!! 😀
