Re: BEKO WMB 10W Door Seal Replacement
🙂 I managed to get the spring back on OK with the help of an extra pair of hands………but 🙁 ……I think I’ve just found out why the seal came off!
When a wash was put on there was a lot of vibration and a banging noise while spinning, I think the drum bearings are worn, there is a lot of ‘play’ on the drum. Can these be changed ‘in situ’ or does the whole drum have to be removed???
Your advice would be appreciated again.
