Beko WMB 81445 L Pump Problems
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WMB 81445 L Pump Problems
  • #83873
    jeffwoodford
    Hi everyone,
    I have a Beko ECO WMB 81445 LW washing machine and it is not draining water. The drain pump is not running as it can not be heard and also water stays in the machine on a wash or drain cycle. Not sure if the re-circ pump runs during wash cycle.
    I have removed the drain/re-circ pump assembly and tested the resistance on both pumps. Both measure around 160 ohms. both do not beep on a continuity test.
    Do the pumps sound like they are in good order?
    What else might be causing the issue if the pumps are ok?
    any advice greatly received.
    Jeff
    #424071
    jeffwoodford
    Re: Beko WMB 81445 L Pump Problems
    update, I just put 230v across the terminals on the pumps and they both spin, so guess something inside the machine is at fault?
