Re: Beko wmb 81445lw won’t spin
F13 is a communication error between the motor control card and the machines timer
These machines are not easy to diagnose due to the complex electronics and 3 phase motor, all you can try after turning machine off and unplugging is to remove and replace signal wires ( ribbon cables or small wires) in case the connections have got dirty or loose
After that it gets harder and the test proceedures get very technical
