Hi, Have reset it numerous times. Replaced PCB and programme switch.
On cotton it will let water in for short burst then discharge it again, it will do this in cycles. It was a new machine but went in to storage for 18 months so no guarantee. There is no blockage. Motor has never moved.
If I select ‘spin’ the motor does not attempt to move (at any time) but discharge pump will continue to work. Both PCB’s show same results.
Motor runs free when turned by hand.
Do get code 4060 when I switch on and hold down cancel button, then all items light up on the display, if I press cancel again it goes to a fill mode until I press cancel again then it goes to discharge mode util I switch it off.
There are two pressure switches, one by the door catch which clicks OK. The other pressure switch is located at the top of the unit but not sure if this is OK or not.
Tearing my hair out by now! All help appreciated.
