Re: Beko wmb 91442 lw
Infamous Askoll motor, it uses a hall sensor for speed feedback instead of normal tacho. Diode mounted inside back wall down to left gives problems & sometimes needs changed if problem is no motor action.
If its sticking on 20 mins i’d check coil of inlet valve, it may not be taking in water for rinse, just a thought.
Continuous pumping would make you think it has’nt registered empty, check pressure vessel, pressure hose hasn’t come off the pressure sensor, etc.
Check drain hose is’nt too far down drain pipe causing syphoning.
