Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko WMB10
- This topic has 8 replies, 5 voices, and was last updated 20 years ago by
mellork.
March 20, 2006 at 2:34 pm #16510
mellork
ParticipantRecently had my kitchen refitted and plumbed back in our Beko WMB10 Washing Machine. All has been fine for about two weeks but yesterday following a wash cycle found a pool of water in front of the machine. It appears the leak is underneath the machine. I cleaned out the filter that had a coin and some other bits and pieces in it. I’m not too sure if this is the problem. Anyone got any suggestions at things I should check or can test before calling an engineer?
March 20, 2006 at 2:43 pm #170164whitevanman
ParticipantRe: Beko WMB10
coins and bits can cause holes in outer tub assy suggest visualy inspect tub for damage 1st.
March 20, 2006 at 3:36 pm #170165mellork
Thanks for the advice Whitevanman but I can’t see any physical damage any other ideas?
March 20, 2006 at 4:12 pm #170166Goatboy
ParticipantDid you check the door seal for holes?
Remember, Power off first!
March 20, 2006 at 7:57 pm #170167robdray
Also worth a quick check that there isnt a trace of water on the front of the machine from the bottom of the door …ie ( door seal letting small amount of water by ) …
March 21, 2006 at 12:29 am #170168Penguin45
Not forgetting the soap drawer and box getting clagged up……….
March 23, 2006 at 8:45 am #170169mellork
Thanks to everyone for their input. I’ll check out these suggestions and I’ll come back with my findings.
March 23, 2006 at 6:12 pm #170170mellork
Have just checked our washing machine as some of you suggested, Surprise, surprise when inspecting the door seal I found a small slither of ceramic wall tile embedded in the rubber. Its not a pin hole more like a cut. Is it fair to say that this is almost certainly the cause of the mystery water leak? If so can I purchase a new seal and fit myself or should I call an engieer to be safe? Once again to all thanks for the tips,,,
March 24, 2006 at 11:47 am #170171robdray
Glad you have at least ascertained what the problem is … in terms of safety and ease, far better to let a pro sort it … use the Repairs@ link on the left of the front page to find your nearest repairer that will work on your machine … or just click here
http://www.ukwhitegoods.co.uk/modules.p … whitegoods
Rob
