Call to the above machine, water not heating and not filling with hot water.
I can only get a supply to the cold valve, during a hot fill the hot valve s not energised.
Test show the wash element has an earth fault so logic suggests this may affect the hot valve supply.
I disconnected the element to remove the earth fault and ran the machine but the hot valve still wont energise.
Does anyone know if:
An earth fault will affect the hot valve?
If the hot valve takes it’s supply through the element causing loss of supply if disconnected?
Any help would be appreciated.
