Beko WMB61221w washer not heating.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WMB61221w washer not heating.
  • #79644
    Madmac
    Customer complained that this machine washed endlessly and did not move to rinse,I left it on a cottons wash for a while and was getting no power to heater.
    Had a close look at the PCB hoping to find a dry joint on a relay but no joy.
    Anyone know if the heater relay is a common failing on these ?
    Thanks,
    Eddie.
    #410102
    Re: Beko WMB61221w washer not heating.
    heater relay are suspect on any machine
    the way i test them is to run with board out and test voltage at relay coil. you could always 2 wires on and watch voltage to see if it energises
