Hi, I have a beko wmb71231, this week the motor failed with one of the windings going short to earth causing the fuse at the plug to blow and taking the socket trip out also, I have replaced the motor and all seemed well, the machine shows no faults and I can select any program and seems to work without fault, my problems is the door is locked and the ready light flashes at the end of a program constantly and the door remains locked, I scrolled through the test sequence ok, I have tried to hold the start / cancel button but it doesn’t seem to reset ie. It doesn’t complete a drain sequence, any ideas??
