Beko WMB714422W
  • #97713
    dunston
    The washing machine fills then turns clockwise once then stops. The relay clicks but the motor doesn’t turn anti clockwise.
    The machine will drain and spin clockwise.
    Anyone had this fault?
    Also what is does the PCB DC Module do?
    #469168
    i would inspect the main board. one of the relays reverses the motor. its possible it just may have a bad solder joint
    the dc module converts AC to DC for the motor. if it failed the motor would not move so its likely its ok
    dunston
    Checked the main board. Couldn’t see a problem. So I re soldered all the joints on the relays. Put it back together. Worked a treat.
    Happy customer, happy life.
    Thanks Dave
