BEKO WMB71642W
  • #88687
    mjwilmot@sky.com
    E18 Error Code. Can’t use machine – ‘start’ symbol flashing?
    BEKO WMB71642W. Had suds coming out of detergent drawer. Stopped machine, rinsed and spun and unloaded washing. Now the ‘start’ symbol (triangle) is flashing and it is stuck on one wash program. Can’t do anything – tried 3 sec cancel, tried ‘start’. Held start and turned on, got error code E18.
    #438993
    Re: BEKO WMB71642W
    E18 is an unbalanced load error and its more of an advisory more than an error
    Beko’s answer is
    Reasons for terminating the program before spinning as a result of unbalanced load detection.
    1) When you use the machine with less quantity of laundry, it may pile up at one side of the drum. When high speeds are reached under an unbalanced load, washing machine will likely be damaged. For this reason, when the unbalanced load in the machine is calculated as more than the limit value, it will not spin for safety purposes.
    2) When the machine is operated with only one pullover, bathrobe or towel, piling up probability of the laundry at one point in the drum is quite high. Try not to wash such laundry as one piece as much as you can.
    mjwilmot@sky.com
    Re: BEKO WMB71642W
    OK Great, but can you please tell me how to reset so that I can use it. Thanks
    #438995
    Re: BEKO WMB71642W
    there is no reset on Beko
    dont know without checking has this machine got a child lock if yes is it on ?
    mjwilmot@sky.com
    Re: BEKO WMB71642W
    Child lock is not on. Do you know what I can do so that I can use the machine…. please
    #438997
    Re: BEKO WMB71642W
    you say its stuck on a programme will it run that programme ?
    all i can think of is your motor brushes. think if they are not in contact with the motor due to wear everything stops
