beko wmb71642w
  • #92696
    mikehha
    good evening all some technical info or help much appreciated on this. I have this w/m that goes through a wash then refuses to go into a rinse just sits there and pumps until the tap symbol comes up you can then put it on to a rinse which it dose no fault code coming up but when I was trying to jump programs I think I got a e07 do you get many problems with pressure switch on these m/cs
    #451913
    timdowning
    Re: beko wmb71642w
    Had one with E07 and the pressure switch / sensor sorted it!!
    Just plugged the new one in & away it went.
    #451914
    mikehha
    Re: beko wmb71642w
    just a quick update fitted the pressure sensor it still stops after the wash wont go onto the rinse no fault code logged (thanks for the info electrofix).just 24 min on timer and the tap symbol flashing.Which are the YF1 buttons.
    #451915
    Re: beko wmb71642w
    short answer to that is I don’t know. been through all other info and its not mentioned. it will be one of the user buttons but don’t know how you find out which
