Beko wmb81445lw
  • #87501
    Andy jones
    Any help to get into diagnostics on these machines
    Tried the error codes thread but no luck
    Andy
    #435061
    Re: Beko wmb81445lw
    there are 2 machines with the same model
    have pm’ed you the first one
    prod code 7110842400
    model DD WMB81445LW Beko 8kg 1400rpm
    Andy jones
    Re: Beko wmb81445lw
    Thanks Dave
    Haven’t seen it as of yet but she could only find Eco wmb81445lw
    Andy
    #435063
    Re: Beko wmb81445lw
    only the prod codes change they are both labelled eco
    second machine is
    prod code 7110843600
    ECOWMB81445LW-1 Beko 8kg WM White
    the manual is 6Mb don’t think I can pm that but if it is that one will try emailing it
    Andy jones
    Re: Beko wmb81445lw
    She’s just texted me Sn 13-400692-01. Prod 7110842400
    Andy
    #435065
    suedehead1
    Re: Beko wmb81445lw
    i have a problem with the same machine when you try to set a program it just flashes 28 the end and wont do anything any advice on fault or how to access codes welcomed.
    #435066
    Lawrence
    Re: Beko wmb81445lw
    We have one doing the same,wont let you access diagnostics at all.
    we seem to be having issues with the BLDC motor style machines with locking up,Beko tech say the machine isn’t registering the fill, then someone else at Tech says carry out a factory reset on the board and leave for 2 hours…
    #435067
    suedehead1
    Re: Beko wmb81445lw
    how do you do a factory reset
