Beko Wmb81445lw fills at end of spin cycle
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko Wmb81445lw fills at end of spin cycle
  • #81988
    colly
    Dear all
    I have looked at the above machine and observed machine would fill at the end of spin cycle.
    Beko WMB71445LW
    I have changed the board and did a spin test hooray it worked,pt number 2827682050.
    When the customer done her first wash, she found the fault had reappeared.
    If you select spin only,it does now fill at the end of spinning .
    Any ideas?
    Colly
    #418353
    Re: Beko Wmb81445lw fills at end of spin cycle
    had same fault on another Beko auto ended up fault was machine was connected to hot water not cold
    just had another thought. i am assuming my machine was sensing it was hot at the end and trying to cool things down by adding water. So, if the ntc was faulty it may do the same thing
    #418354
    colly
    I will check this out
    Thanks for your swift reply.
    Colin
